View your configuration to review the information and ensure it is correct.
Use the data in the following table to use the show filter acl and show filter acl config commands.
                             Variable  |
                             Value  |
                             <1-2000>  |
                             Specifies the ACE ID.  |
                             <1-2048>  |
                             Specifies the ACL ID.  |
